Will it be straightforward to replace this unit (and other matching ones) with ones that have easily replaceable bulbs or are they wired differently?
No, not wired any different and can be replaced with 'normal' ones but be careful to get ones with the similar details.
i.e. if they are 12v, instead of the normal 230/240v then you will need to get a 12v one, (or set if replacing the others.).
Tip: As you start to pull it down slide the fingers of your other hand up to form a ring around the unit. You should feel what feels like two stiff wires running upwards on each side. Keep a firm squeeze on them as the unit comes out to prevent them snapping against your fingers.
