Hi all,
I'm having a 'mare and would appreciate some advice.
I had a problem with my cold water feed from the tank and traced it to a dodgy stopcock just below my tank. The stopcock was part of the vertical steel (i assume) pipe that ran from the tank and it has threaded joins. I cut it out and intended to convert to 22mm copper to add in another stopcock or lever valve. I thought I would have no problem using 28mm compression fittings on the steel but turns out the steel has a 26mm diameter and the fittings are way too loose. I also had a 1 inch to 22mm solder fitting which I tried the 1 inch end on the pipe and it also seems too loose.
I'm no plumber just a confident enough diy'er, so does anyone know how I can go from this 26 mm steel to my 22mm copper and save myself having to pay for a pro?
Cheers
Cheers
