I literally moved the light a few inches forward and all 3 cables needed extending. One of the cables I replaced... another one I might be able to replace as it goes into the toilet room behind so only through 1 joist. The switch line needs extending though... which crimps do I need to buy is it the blue ones for 1.5mm? Also do I tape the cables individually after then use that special rubber tape over the whole thing at the end? I think I have a ratchet crimping tool which seems decent.
The crimped joints I did above had a little movement into them but didn't pull out. After taping obviously the movement is reduced.
Thanks.
