- Joined
- 13 Dec 2019
- Messages
- 81
- Reaction score
- 0
- Country
Hi guys, looking for help. I need to disconnect my old sink and give it a good old clean before I set the plasterer loose on the wall.
In the first pic, I assume my red boxes are isolation valves and if I turn them horizontal there is no risk of water seeping through anywhere? The cold water feed comes from the right and warm to the left? (I Assume no risk of me disconnecting the sink and water sprouting everywhere?)
Also on the first pic, once the taps are disconnected and I've isolated the valves, I just turn the white connector and then I can look to disconnect the sink? Green box...
Looking for some advice on the yellow connectors. There is also some electric cabling, but can't see anything connected... Any thoughts?
For the second picture, from looking at some videos online - it looks like I just disconnect the nuts highlighted and then the taps will be disconnected. Is this right?
Thank you.
Thank you.
