Just had the bathroom made over and we have very low hot pressure. It's a gravity system, with the 50 gal header tank about 5 feet above the top of the 45 gal Economy 7 hot cylinder.
Bath, basin and WC cold feeds are mains - the only cold-fed item is the shower (more detail in a minute).
The hot supply is through the bathroom then down to the kitchen and shower room below. The pressure downstairs is OK, but a trickle in the bathroom - not enough to operate the bath mixer properly.
So, probably installing a hot boost pump to boost the whole hot supply (maybe Grundfos UPA 15-90 or a Salamander equivalent - any views?)
But one concern. We already have a Mira Vision pumped shower, drawing from the hot cylinder and the cold tank. I'm worried about how to install the boost pump without putting extra pressure through the built-in shower pump, as I assume it would damage it.
The good news may be that the take-off for this shower is a separate feed from the 22mm pipe coming from the top of the cylinder. It is the first outlet on the hot system, a separate 15mm pipe going off before the 22mm pipe goes on to supply the bathroom and downstairs.
What do I need to do to isolate the shower pump from the main boost pump? Is it enough that the boost pump will be 'downstream' of the shower pump take-off, or do I have to so anything extra?
Any help gratefully received
