and there was me thinking that for a 'stable' door you just have to fix it on properly so it isent 'un-stable'
hehehheh me thinks it time i hid for fear of reprisles
Hang the the top door in the frame first,when done make sure the top door is shut,then hang the second door into the frame pretending it's another frame with the top door in etc....
Don't take any noticed of above unstable lot including me
I have also read that you can clamp both doors together and then hang them as on unit, sounds tricky, I can see clamps being dislodged during the hanging process.
