I've replaced broken panes in windows before and managed well (got lots of tips on here!). They are sash windows and I had to use the linseed putty on the outside bit.
The next project is to put new glass into the door - there is horrible ripple-y glass there now and I want something nicer.
There's two bits: Firstly, there is the big square of glass above the door. I think I'll manage OK replacing this - I can see that it's held in place by quadrant beading nailed onto the inside of the frame. Not that I'm anticipating it to be easy ... Any tips?
The second bit is four "pie" shaped bits actually in the door. Each pie shape is made up of two straight bits, a large curved bit at the "pie crust" and a small curved bit at the "pointy bit of the pie". Hope that makes sense! These are also held together with quadrant beading. But the dodgy refurb means that only some of the curved bits have beading. This leads me to think that it's difficult and the **** who did the crap refurb in the 70s didn't bother.
So: how do I do this? The easy option to me seems to use glazing pins to get the new glass in place and then use the linseed putty ... but that feels weird to be doing on the inside of the door. And we're trying to do our DIY to a better standard.
The other option is to see how I go at using quadrant beading on the big square of glass on the top of the window and get someone in to do the four "pie" shaped bits in the door if it's too hard. Or maybe I could use quadrant beading on the straight bits and use the putty on the curved bits?
The final option is to not bother and "get a man in". If I went for this option, where would I look for this sort of "man"?
Well done if you've got to the end of my essay, especially if you've understood my "pie" analogies!
