I've cut a hole where I want to put a new double socket, but there's nothing there to fix it to! Do I have to make a really big hole to find some supports or is there a clever way that I don't know about yet?
those boxes can be fitted on lath and plaster but cutting the hole requires great care (its very easy to break the laths away from the plaster by mistake and end up with a very messy hole that doesn't have the strength for fitting one.
