How do i get instant hot water
27 Sep 2007
Lancashire
Hi
have a worcester combi, and always have a long delay before the hot water comes thro.
What do i need to upgrade the existing bioler to permit instant hot water ?
Nothing can be done if your boiler is operating correctly.
Most combis take 10-12 seconds for the water to get reasonably warm.
Some have a preheat built in which cuts this to 5-6 seconds or longer if the pipe run to the boiler is significant.
Tony
Hi
You can add a secondary circulation DHW loop. A loop from combi back to the combi with all DHW taps teed off this. Only if the DHW on the combi is activated by a flow switch only. A bronze pump, two double check valves, a pipe stat, timeclock and heavily insulate the loop.
Hi
A secondary loop on a combi ? Sounds like alot of work and wasted gas to me.
Bit like trying to make a petrol car run on diesel. Hmmmmm, I wonder.
