I want to take a couple of rads of for decorating and have turned both valves off. The rads have TRV`s fitted and I turned them all the way in the clockwise direction to 0 marked on the valve and the same with the opposite valve.
When I went to undo the rads the TRV was obviously still letting water in as when I loosened the nut water was coming through at pressure.
I was sure that both valves are off so fired up the heating to see if the rad would get hot which it didn`t. I loosened the nut again and warm water was coming through still under pressure although the rad is stone cold!!!!
What is happening and why is water still coming through....
Is there something I have missed about how to turn these TRV valves off and if they are still on why is the rad not hot
