Hi guys, first post to the forum.... I've been lurking for a while!
I've got an Edwardian house with a damp problem along one or two walls. The damp seems to be penetrating damp coming in from an external wall that had an incorrectly built french drain where the concrete was touching the wall rather than the french drain going down to earth. I've corrected this and need to dig a little further but also have a problem with render that has been put in from soil level up to about 1-2 feet above the driveway.
I believe the render that has been put in is cement render and during the course of time this has now got some hairline cracking which is trapping water and causing the penetrating damp.
It's my intention to remove all of the cement render and to replace with a lime render to the same height - I believe this to be a better solution to allow the wall to breathe properly and correct the problem. I'm not sure as to whether a hydrating or non-hydrating lime render would be best but this will also coincide with me adding some additional vent bricks.
Can you please advise as to whether this is correct, other things I should think of and how I can identify the render I have to know whether it is already a lime render or not? I'm wondering as maybe it was a cmement render with lime added... I doubt it but would be silly to take it all off only to replace like with like.
Thanks in advance for any assistance.
