I wish to install TRVs on my radiators (except the 2 nearest to the room thermostats). The system dates from ca 1970.
The caps on all the rads are identical at both ends and (square nut approx 7mm) but flimsy and broken and so I cannot turn rads on and off. More importantly, visually there is no difference between the valve and the lockshield. As the system is well balanced at present (all rads heat up well) I would prefer not to change the settings of the lockshields and just touch the valves. How do I easily identify which end is the lockshield and which is the valve?
Any help would be appreciated.
