how do I increase pressure in Baxi Bermuda 552 back boiler?
13 Nov 2009
Sussex
A friend of mine has a Baxi Bermuda 552 back boiler fitted behind her gas fire in her lounge. One of her radiators was leaking and has now been repaired but a lot of water was lost from the system. I cannot fathom out how to refill the system or increase the water pressure (if necessary). Does it automatically refill itself or should there be a pressure gauge and in-fill tap somewhere on the system? I have looked everywhere. Any suggestions?
i assume you did not fix it therefore it should have been refilled and tested by competent tradesman however try venting rads and check f+e tank in loft make sure its full
it is a traditional open vent/feed system so the water should have been isolated in the loft while the work was done then tutrned back on, the rads would also need to be bled
