How do i know if my lock conforms to BS3621 insurance
15 Dec 2010
London
Hi, i recently had a new front door installed. My insurance stipulates that the lock must comply with BS3621 standards. I can's see anything on the lock but given it's a new door and a new lock, can I assume that it is compliant? The fitter is no help BTW !
If it's a 5 lever mortice in a timber door [should be marked on the edge] then it should be OK, even insurance companies do not know what it is they are stipulating.Was you installer fensa registered?
if it is, it will have the kitemark and the year stamped on the fore-end (the brass or steel plate that is visible on the front of the door)
It would help if you said if it a wooden or plastic door, and a mortice lock (like a Chubb) or a nightlatch (like a yale) or what.
Have you got an itemised receipt?
A photo would help too.
This is a typical BS mortice deadlock
52213_P
This is a typical BS nightatch (the cylinder housing on the outside of the door is huge compared to an ordinary Yale type)
88810_P
