I have an area in the back approx 8mx4m that I want make into a gravel patio. I picked up 14 600mm x 600mm granite slabs to lay individually, the area is a former patio so the grounds a well compacted mix of sand, aggregate and heavy clay.
The slabs should be level with 200mm high sleeper edging and flush with gravel surface. On a budget but whats the best/simplest way to accomplish this?
The end result should look something like this.
