i do not have a powered mixer. I was thinking of using one of those big plastic carry tubs to mix in. I do have a drill, can you buy a mixing attachment or is it best to mix by hand?
yes mate you can buy a mixing paddle to fit an electric drill, just be careful when you trigger the drill as it will run faster than a proper mixer, and could throw a slurry all over, to start off with, just pull and release the trigger a few times, and add adhesive if its far to watery
