How do I plumb waste on a back to wall bidet
5 Jul 2006
Yorkshire
I am contempaling fitting one of the flat backed 'back to wall' bidets but I am at a loss to figure out how to plumb the waste onto it given that once it is installed 'back to wall' there is no access to the plumbing. I am presume the hot and cold feeds can be achieved using flexible piping but the waste, trap etc has me baffled.
All of the pipework will come through the wall, If you havent already a bidet in situ you will probably need to rip out the old plasterboard to pipe and then replasterboard and plaster after. You would know where to put the pipework by measuring the inlets and outlets on the bidet.
If access is a problem, you can always fit access panels behind the bidet which are in effect a false wall. :idea:
:D :cool: :D :cool: :D
The only problem with that is Im putting the bidet up against one of these modern 'egg box' type walls so I dont think that will work.
