I've some old (and irreplaceable!) rollerblades. The blade/wheels detach and you can walk in the boots. The foam joining the sole to the boot has degraded over the years and is now soft and sticky. I want to remove it and then fill with some black no-nails CT1. The problem is removing every last bit of the foam so I can ensure the CT1 has enough clean surface area to stick to. I've tried methylated spirit, white spirit, soapy wipes. The only thing I can think of left is to either rub in sand which hopefully will bind with the foam. The texture of the foam (when squashed) is like a sticky putty, like blue tack. Any ideas how best to get rid of it for a clean finish?
