Hi again,
as per the title, the bathroom has a Grohe tap/shower fixture w/ a diverter.
the thing started failing only a few weeks after installation, had it replaced and now, about 2 years later, it's seemingly failing again; when you lift the knob to activate the shower it's getting very reluctant to divert, you have to turn the water flow up higher than usual, and when finished the knob is not lowering correctly. Is it usual for valves to need replacing this often?
anyhow; is it an easy enough job to replace the valve? Do i need any particular tools?
as for the valve, i believe this tap is called a "Eurosmart" as per this link
https://www.heatandplumb.com/acatalog/grohe-eurosmart-bath-shower-tap-deck-mounted-chrome-25105000
(though in google that name comes up w/ quite a few other pics too) so is that "silkmove 56mm cartridge" the thing i need to find and order?
TIA
TIA
