I expect, and hope, that there is a simple explanation for this problem but I am totally stumped, as is a plumber I have employed. I have bought a contemporary looking close coupled toilet which is designed to sit tight up against a wall. It is to sit on a tiled timber floor. The problem I/ we have is that the securing holes for the screws are situated within the body and at the rear of the pan , not visible on the exterior face of the toilet, if that makes sense. It would be possible to drive home screws using a very long, thin screwdriver through the holes at the top of the pan designed to site the cistern, but once the pan is secured, it is then not possible to then secure the cistern to the pan. Obviously the cistern can be secured ito the pan beforehand but then I am not able to access the screwholes when the toilet is palced against the wall.
Apologies for this epic question but I am trying, and probably failing miserably, to explain the issue in as much detail as possible. Can anyone help please??
