I'm hanging a new hand basin on my newly tiled bathroom wall. I tried to use a type of 'rawlbolt' in which a sleeve is expanded using a tapered end of the stud. The studs just pulled out of the wall when I tried to tighten up the basin.Unfortunately, my walls are a combination of plasterboard and tiles on top of plaster & brick and thus are quite hollow and fragile for the first 75mm or so. I've been advised to use chemical or epoxy resin to secure the bolt along its whole length inside the wall. Is this correct? Is there another means of doing this? The basin is stopping me finishing this project...
