Hello...I have installed a false ceiling in my bathroom, 2 inches below the original plasterboard.
I have cut out an area of 7inches in the original plasterboard directly above each of 5 x 20w low voltage downlights and removed all insulation above the bathroom.
I have one Holotronic HTM 105/230-240 transformer 35-105 W which I am assured is adequate for 5x20 w lamps.
The transformer has 3x2 connections eg. SEC / SEC / PRI
Each light has a seperate joint block with the trailing wire for the lamp.
I am useing the original pull cord.
Please...how do I wire the lights?
Many thanks....Mike
Many thanks....Mike
