if its a sealed system,the cartrige 1 or aerosol can be fed in at the filling loop and avoids any mess at radiators.the aerosol 1 will add about 1/2 bar to your system pressure.if open vented tie up/turn off ball cock at header tank and drain and a bottle of your choice,refil and bleed
