I am looking to build a roof over my patio. One side fitted to brick wall, the other to be against posts, with a poly roof.
I'm told using ground brackets is best, fitting them to the paving slabs.
Trying to work out how to build the roof. Is it best to build the frame first. and then raise that to the posts. Or to fit the posts. Fit the beam against the house. Then fit each length from beam to the post. And start to drill the rest of the frame together?
If that is right, how do you fit the two length posts of the side of the roof, to the beam? With a bracket (that has a hinge?).
