How do you clean out a water tank?
24 Nov 2008
Essex
I have a water tank on my roof (not attice due to flat conversion years ago). I recently had my flat roof re-felted and the tank lid replaced. I think some gunge got into the tank while the work was going on as my hot water has been not running as hard since. The heat is fine - it just doesn't ran as hard. I had this problem before in another flat and someone had to come and flush my pipes out and clean the tank. Is there an easy method to do this myself (I am not too hot at DIY)? Thanks
Issolate the mains feed, drain down via hot taps and clear obstruction and clean out tank.
With hot taps still open, open mains feed and flush out tank, when running clear close hot taps and allow to refill.
Should of said turn off programmer to heating and hot water before draining. when you have done the above turn programmer back on.
Drain tank!
Get a bucket and scrubbing brush and jump in and start work.
Wash all the dirt away with a hose and then fill up and add some sodium hypochlorite ( bleach ) and leave for about an hour to kill any bacteria before flushing through for about an hour or until the smell of chlorine ceases.
Tony
Thanks for this. Just one question - how do you 'open the mains feed and flush out the tank'?
He means that you let the water run in to the now clean tank and out via all your hot taps to flush the system.
If it was me, i would shut the feed to the tank and drain it onto the roof. Clean it with the feed shut at the tank OUTLET but still allowing the dirty water to drain onto the roof as i clean. Now fill and flush as above.
