How do you disconnect compression fittings?
11 Sep 2008
We have bought a new kitchen tap but when going to install it - under the sink there are brass push fittings which I think are called compression fittings installed. How do you disconnect them? Can anyone help please?
Sorry I don't know the answer but it is known as a push-fit connector. A compression fitting is the type with an olive and a hex nut.
You will probably get a reply quicker if you post this in the plumbing section of the forum.
Without a picture it's possible to misinterpret your words, but the following might help things along.
Copper push-fit:
Plastic push-fit (Hep2o):
Plastic push-fit (Speedfit):
Brass compression:
Probably this if OP describes it as brass -
You should be able to buy a release tool from any plumbers merchants for not much money
