Hi All,
I've posted here and had many good responses so, here I am again. Thanks in advance.
I have a garage extension I am carrying out and i have been advised by building regs to put some batten on the wall (thin 25mm) then put some breather membrane over it.
once complete I can then put up my stud wall (100mm) and insert my insulation in between.
finally I can put plaster board on it, sounds simple enough
but!! and heres the problem what do I fix the stud to do I go straight through the membrane and into the wall or into the batten but it may split?
Also what type of screws/fixings do I use?
Any info would be great
thanks
hogey
thanks
hogey
