how do you get a new belt on a hotpoint washing machine
29 Oct 2006
Kent
how do you get a new belt on a hotpoint washing machine model is first edition
Loop the belt around the motor shaft, cable tie it to the pulley, turn the drum and it should pop on.
I used to slaken the motr, put belt on, then re tension motor
he suggests using a cable tie to hold it to the pulley, cable tie is a plastic thing for holding cables, any diy shed sells them
Yep, I used to do the same but the cable tie method works and takes a fraction of the time to do the job.
