I'd like to top up my loft insulation. It's 100mm presently, and I'll add another 170mm laid over it. I'll no longer be able to see the joists, or walk on them easily. What do people do about getting around the loft in this case? Is there some trade secret? Or. does the top up insulation have to be removed /rolled back prior to walking on the joists? I was thinking of the case where you have to get to a light fitting, cable or pipe. I'm assuming that loft boards can't be used any longer as it would compress the insulation, probably to the point of popping off the ceiling plasterboard.
This is such a common occurrence, yet I've read scant advice about accessing the loft subsequent to topping up insulation. I'm hoping that the loft doesn't become a no go area?
