How do you measure coving?
9 Feb 2010
Wickes/B&Q/Homebase say they do 90mm, 100mm and 127mm width coving.
How do I measure my existing coving to see which size matches?
Is it the diagonal, or one of the flat faces?
Diagonal.You will also need the same type of coving i.e plaster or foam to match existing. I used the light weight coving from selco, cheaper than the sheds and quick and easy to fit.
