Hi there,
I have recently started a self build project converting an old farmhouse into a modern home of which the walls are up,and roof trussing nearly finished. Im planning to tile the roof myself and have pretty much figured out what to do but a few questions still remain unanswered and im hoping someone can help.
1. How do i tile up to a block wall? (sunroom is stepped down from main house.I have cavity trays fitted following intended roof pitch so do i fit lead under the lead in the trays and flatten down over tiles that meet the wall)
2. is there a particular way breathable membrane goes onto a dormer??
3. Do valleys need or have to have extra membrane ?? the reason i ask this is the old roof i took off had lashings of pvc type plastic in the valleys
4.Ideally i am going to attempt to cut the tiles into the valleys and not have lead ones.Im using a 6" rosemary tile but do i still have to put lead under the tiles?? (again,this is how it was done in the old house and it looked in my opinion alot nicer finish)
Many thanks in advance.
