How do you vent a CH Pump ?
11 Apr 2007
Aberdeen
Hi
In our CH system we have a system boiler plus 2 underfloor heating manifolds.
The is a circulating pump on the boiler together with a circulating pump on each of the manifolds.
When the CH is running there is a slight noise coming from each of the pumps which I assume is trapped air ?
To vent this air should I simply remove the vent plug at each of the pumps, when the CH system is running, to let the air escape ?
Cheers
if you want to vent the pump it will have either a silver cap with a slot to undo or a nut
Gents
Many thanks for your replies.
So is it a simple matter of turning the CH system off when venting the pumps ?
The reason I ask is that the Grundfos manual suggests setting the pump to Position 3 with the pump running and then opening the vent to let any trapped air escape ?
I always find it best to vent a system when it has been left off over night, gives the air a chance to rise
