We have an Ideal Logic Heat 12, Megaflow tank and standard (S plan ?) plumbing for radiator valves and hot water cylinder. It all seems to work ok but I’m confused by the boiler temperature control.
The manual says it ranges from 30 to 80 with an E setting at about the 2 o’clock position. If I set the control to a lower than E setting I’m told it will save money and run the radiators cooler. If I do that, how does the hot water get to the recommended 60c for bacterial protection ?
With HW scheduled to be on, I’ve tried setting the boiler control to about 11 o’clock and the system fires up as expected. After a while the boiler stops firing but it seems the pump keeps running and the HW cylinder valve stays open as if the cylinder thermostat hasn’t reached the required temperature. This would make sense if the flow temperature was say 50c.
As far as I can see there is only one flow into the Megaflow cupboard and this is split by the valves to either / both the cylinder and radiator circuits. So how do I get the cylinder to 60c but run the radiators cooler ?
Many thanks
Many thanks
