How does it work?
16 Feb 2007
Hi
Have a dimmer switch connected to a pendant light. There is an additional switch on the other side of the room.
Currently connected as follows
GALLERY]
However, the switch on the other side of the room does not switch on/off and the light remains on even pushing the dimmer on/off. IF I take away red cable [GALLERY=media, 28018][/GALLERY]
the switch will turn on/off via dimmer but not using the other switch! :? Why? Surely the red wire should connect into L1?
How should this be wired? Do yellow and blue cables have red sheathing to denote live? I am normally ok with electric basics but lighting baffles me!
Have a read of Wiki regarding two way lighting
//www.diynot.com/wiki/electrics:lighting:two_way_lighting
This will allow you to check the cables.
Did the dimmer just stop working? Or was it working before you changed something on the circuit?
If the dimmer did just stop working and the bulb is okay (and the right type and size) and there are no obvious wiring issues then the dimmer may be faulty.
Either test it with a multimeter or change it.
The sketch does not look like a typical wiring set up on closer inspection.
Or to be more precise, it is wired up wrong.
The 2 core switch wire, red and black, are in the same terminal so the light will remain on.
I would expect to see the 2 core red in L1
Then the 2 core black in L2
The 3 core red in COM, ASSUMING red has been used at the other end common.
Assuming above, the 3 core yellow in L1
and 3 core blue in L2
If red is not common at other end, use appropriate wire, and remaining two for L1 and L2.
Thank you very much for your very helpful reply :)
As I understand it the switch should look like this?
GALLERY]
GALLERY]
Rusty... it might be better to explain how a one way and two way work with the old colour conductors and the way I was taught.
One way - the red (T&E) conductor goes in C and black conductor(T&E)(sleeved with red) goes in L1. This is the traditional one way for info only.
Two way switch one - (This is the one with Twin and Earth and 3 core cables present.)
(T&E) red conductor goes to L1 and black (sleeved with red) to L2. (Three Core & E) red conductor to C - Yellow conductor(sleeved with red) to L1 and blue conductor(sleeved with red) to L2. - As you have it.
Two way switch two (assuming it is not linked to another light) should have three core & E only. Red Conductor to C - Yellow conductor(sleeved with red) to L1 and blue conductor(sleeved with red) to L2.
The three core colours should alway match the terminal descriptors in each switch.
