How d'ya turn off a TRV
3 Aug 2005
Surrey Hills
I want to replace a rad and there is a Honeywell TRV at one end.
How do I turn it off so that all the water in my heating sys won't leak onto my bedroom floor !!
If I turn the TRV to '0' does that mean it is fully off regardless of temperature.
Many thanks.
you need to remove the top section of the valve. usually a ring that will screw down to allow the TRv body to be removed, then you need to screw on a big blue cap, a bit like a coke bottle top to shut of the vale completely. You might habve the blue cap laying around in a drawer. failing that go to a plmubers merchant and buy one. or burrow one from a friend/relative/neighbour who has the same sort of TRV
Sorry forgot to mention. setting to 0 will not fully shut the valve safely enough that you can remove the radiator for any length of time, as young children like to play with radiator valves.
eh? :confused:
just turn it to zero and tell everyone to not touch it.....job done
Once the rad is off for extra safety put a 1/2" cap on the T.R.V, just in case :)
Some TRV's only turn back as far as the anti frost sign *, these types of valve heads have one or two little plastic pegs in them, you will have to pop these out to turn too zero.
Depends on the honeywell trv.
Some turn off off off, some turn off until cool.
And some will leak anyway.
Remove head, lay something like 4 x 5p coins on the pin, replace head and turn as low as... then a bit more.
Then put a poxi cap on!
