I need to build a wall that is roughly + shaped, the north south wall is approx 12m in total, so 6m per "leg", and the east west wall is 20m long (10m per leg). The 10m legs are 3m high (and will bear load of a floor deck/storage), and the 6m legs are 5m high (not load bearing).
These walls are being built internally and are not subject to wind / side loads, nor do they have any retaining or insulating purpose, it's just to divide a clear space into sections (with doorways), with storage on top of a deck that rests on the shorter walls
I've attached a sketch, just wondering how these walls can b constructed with regards to block on edge, block on flat or tied cavity?
