how High the standpipe for dishwasher drainage
2 Feb 2006
Lincolnshire
I have just brought a Bosch slimline dishwasher which I have managed to plumb in the cold water supply but before I connect it up I was wondering how high the stand pipe for the drainage (outlet pipe from the dishwasher) how high it has to stand out of the ground so that I do not get any backflow up the pipe as i have laid a new drainage pipe to the outside drain and am very concerned
I hope that this makes sense
dave
Should be in the installation instructions, think its 1metre, you need to ensure that air can enter the waste pipe that the hose from the d/washer will fit into
thanks I did try to look in my instruction manual but the details were a little misleading so thanks for you quick reply
Dave
Thank you
That makes sense as if it was to be 1 meter then I would struggle to get it to fit under the work top
regards
dave
Blockage, I only said 'I THINK', I suppose I should have known it would be less than a metre as the work top is that height.
It's not so critical for a dishwasher as a washing machine - the outlet has to be high enough to prevent syphoning. In a dishwasher the standing water level is quite low.
Thank you all for you help
I have succeeded to install my dishwasher and all seem fine I hope that I did not offend any one but may I add that the information on this sight has helped me very much
thanks once again
Dave
