I'm in the process of installing a built in oven with a microwave/cooker located directly above the oven and in the same unit. The builder has installed a standard cooker isolator switch on the wall and has left a 6mm tail to connect to the oven only, nothing for the microwave. The cable from the isolator switch is not long enough and will need to be joined. In addition there is no electrical outlet for the microwave/cooker to connect to. So as to hide all cables etc I'm considering locating a second isolator switch for the oven complete with 13amp outlet for the microwave/cooker.
To avoid installing the second isolator in a cupboard I intend to locate it behind the microwave/cooker but unfortunately this would mean that the isolator and cable from the microwave will be in a location that will be subject to the heat disappated from the oven located below. I'm not worried about maintenance, as previously stated there is already an isolator located outside of the units and the breaker and cable will handle the load. I'm concerned about the heat damaging the second isolator and/or cable from the microwave. I could at a push locate the second isolator in a unit beside the oven but my daughter is not happy about this. I'm concerned with safety not astetics. Any help or advice much appreciated.
Regards to all
Mal Dinsdale
Regards to all
Mal Dinsdale
