How long can a 'T' be
22 Mar 2014
Devon
Im currently hanging radiators and plumbing for heat.
The boiler uses mixer valves with a flow and return.
Of what we could call the 'primary' flow and return circuit I need to run a T, I'm doing this in 22mm also before dropping the last 2m to 15mm. Whats the max length off the T of the main flow and return I can use? (22mm).
boiler connections are 28mm, I'm running about 4m of 28mm from the boiler then going down to 22mm.
Cheers all.
