How long do router bits last?
17 Jul 2011
North Kent
Hello. I'm thinking of making the skirting and archtrave myself out of mdf. Can anyone tell me how long the bits are likely to last. I've seen some from a company called axminster and I,ve got about 100 metres of both to do.
Many thanks
Carbide tip router blades should last longer than HHS, but they are more expensive.
Wotan
  • Thanks
Reactions: hoq
Thanks. I will get carbon, I reckon trying to guess how many metres a bit can last is a bit like asking how long is a piece of string. Im just hoping one bit will do the job (about 200 metres)
Also does anyone know a good seller. I've seen some I like the look of both torus and ogee but it doesn't say if they are suitable for skirting.
If you plough through trying to take a deep pass at once it will blunt your cutters much quicker than taking several shallow passes.
  • Thanks
Reactions: hoq
Cheaper to buy the mdf already prepared and undercoated, and a lot lot quicker. ;)
router cutter £40 router £150-300 table £100-200 call it £400
These are my calculations.- I actually need about 60 metres of both skirting and architrave. Travis perkins want £3.10 for skirt and £2.75nfor architrave. so £351. But if I rip a sheet of mdf its 85 and 43p a metre so thats £76. I'll have to buy a router I got a table but its cheap so I better have a test. But Id still have the router so its a toss up between the two as its gonna take a lot longer.
I'd just buy the skirting. It'll come in longer lengths, pre-primed, and will save you hours of mucking about.
you need a half inch router
a specialist cutter for skirting / architraves not the general one with the roller bearing
ovolo bullnose chamfered is the style off cutter there are several different ones and sizes available
you need a big cutter for arcas/skirts
http://www.trend-uk.com/en/UK/productsubgroup1/69/Edge_Moulding.html
sometimes you need 2 or3 different router cutters to make a single moulding
  • Thanks
Reactions: hoq
Thanks for the link. Some nice looking ones in there. Best part of a hundred pounds but the main worry is when it turns up it might not be what i was expecting. (this carpenrty lark is a headache, im a bricklayer all you have to do is stick one on top of another :D ).
Travis perkin? you must be rich, SELCO do ready primed skirting for less than £7 per 4.2m length.Architrave is cheaper still.
  • Thanks
Reactions: hoq
Now you're talking. We haven't got a selco round here so I wouldnt have thought of them. But I could pick some up when im in Croydon soon. Worth thinking about anyway.
