I've posted the same question in the plastering forum but thought the tilers may know the answer too.
I am going to plasterboard my bathroom walls using 12.mm board and dot and dab. I will also be using frame fixings through the dot and dab into the brick for extra strength as I'm going to tile the walls using porcelain tiles.
My question is, how long do I need to leave the dot and dab to dry before I start tiling? I read on another forum that it's 2 weeks - i hope not as I've only got a few days off work to get the bathroom done!!
I did think about using dry fix foam, but my walls are quite uneven red brick walls so I'm not convinced it'll do the job
Any advice appreciated.
Cheers
Rob
Read more: //www.diynot.com/forums/plaste...ab-to-dry-before-tiling.343775/#ixzz2BjON8NB0
Cheers
Rob
