How many tees in dhw secondary return?
5 Aug 2008
hello there. have got the secondary return circuit to our furthest tap. An ensuite situated a bit closer to the cylinder has a deadleg to it. If i added another tee to the return to circulate closer to this bathroom should the original circuit still circulate adequately. Or is the rule that there should only be the one loop? thanks
I dont underatand what your saying. Are you assuming your hw is on a loop or do you mean your heating return. If theres a dead leg on hw just cut it out if its a problem
Hi MM is it pumped ?
If you create a second circuit you need to put a lockshield in each circuit
you can have as many tees as u like but each will need a balancing valve to stop short curcit
