Hello all,
We've just had our bathroom re-boarded (dot & dab) and re-skimmed.
We intend to fully tile it, with 200mm x 500mm ceramic tiles that are 7mm thick.
About 95% of the wall surface area is completely flat and will be no problem to tile on. However, on the top righthand corner of one of the windows the walls have ended up uneven (only horizontally). I can’t really work out why, I think it’s something to do with the plasterer putting the metal skim beads a couple of millimeters too far in on the side of the reveal, or a couple of millimeters too far out, on the top of the reveal.
If I place a tile over the top right corner of the window and press it down on one side, the other side of the tile is about 10mm away from the wall. Is 10mm over a 500mm tile a lot to deal with?
There are also a couple of areas on the walls where if you press one side of the tile, the other side of the tile is about 6mm from the wall (again only horizontally). I think this is where 2 plasterboards have been joined and he done poor job of leveling them up with each other horizontally while he was doing the dotting and dabbing and the skim coat has hidden the evidence.
Again, is 6mm anything to worry about in terms of lipping when I get around to tiling? Or will the 8mm bed of tile adhesive iron out all these imperfections and I should stop being such a drama queen?
Thanks in advance
Thanks in advance
