How much feb mix per gall of water or bucket of water.
8 Nov 2017
Hi Building some steps.
Not laid any bricks for years...I hand mix on a spot board small mixes at a time...ie 8 brickie sized trowels of sand to 2 of cement.
I have some feb mix that has been given to me in a bottle with no instructions.
Only laying around 100 bricks.
Anybody give me a guide of how much feb mix per builders bucket full or water...or per gallon/ltr.
I dont want to add to much which I believe is not good.
Nick.
a capful.....
it’s not gauged on water.
off the top of my head it’s gauged on cement weight .ie 25kg which in your case is nigh on impossible.
google found this INFROMATION
Other sources are available
Application Feb® Febmix Admix® - The Original may either be premixed with gauging water in a storage tank or introduced into the mixing drum at the same time as the water. When mortar is mixed by hand it should be well turned over to achieve maximum plasticity. Dosage Feb® Febmix Admix® - The Original is added at the rate of approx 125-250 ml per 50 kg of cement. Always use the type of sand recommended for a particular application. Test mixes should be carried out to determine optimum dosage. Compatibility Feb® Febmix Admix® - The Original can be used with other admixtures provided these are added separately to the mix. It can be used for all types of Portland cement, including Sulphate Resisting. It can also be used in lime/sand mortars as a further precaution against frost.
For the amount that the OP mixes, I’d suggest getting an eye dropper!
