- Joined
- 7 Nov 2004
- Messages
- 516
- Reaction score
- 3
- Country
One for the physics boffs out there...
How much heat (kwh) does a 300 litre cylinder hold..
Ta
Ta
Water holds around 4.12 kj per kg. i need to convert this to kwh so i can understand it.
So if I heat the cylinder to 80 and use a blending valve for the cold water it looks as though I could be in business???
What you are trying to do is something like a storage heater! Put the heat in overnight, when it is cheap. The problem is that, once you have used up the stored heat, that's it; you have to wait to recharge the heater. Adjusting the heater output to match the need can be a nightmare.
In a thermal store system the heat is replaced when the temperature has dropped to say 50°C, by a boiler; though you could use electricity - but that is defeating the object of the exercise.
Unfortunately you are trying to re-invent the wheel; so don't give up the day job
