I appreciate that this is something that I should speak to a SE about. I've had SE calcs done and this included padstone design for the builder. Looking back at photos and the SE calcs I don't think the builder has done what was requested.
We have a 3m knock through on the gable end of the house (so no roof load, but a lot of block) and floor joists notched (badly) into the steel.
Looking at the calc the SE requested a 200mm long pad stone on each side of the steel (2 steels, one for each leaf) onto the block below. As one side of the steel sits on a wall that runs parallel with it, the builder has put a single padstone over the cavity rather than running along the length of the block and built up to the padstone with thermalite type 3.6Nmm2 block. So the padstone rather than spreading the load over 100x200mm x 2 padstones, reduces it to two 100x100mm 3.6N termalite blocks.
Not sure if this is standard practice, other builders appear to suggest that they rebuild up to the padstone with stronger block work. Any idea how much weight will each 100x100mm carry?
Looking into it, I think 1kg = 10N. So does 3.6Nmm2 over 100x100mm equal:
100 x 100 x 3.6 = 36,000N capacity over a single face. Divide this by 10 to give 3,600kg potential load per 100x100 block?
Looking at the weight of blocks, looks like they're about 150-200kg per m2 for each wall. So say 3m x 6m to top of the house = 3 x 6 x 200 x 2= 7200kg spread over 4 x 100x100mm blocks, each of which can take up to 3,600kg in ideal conditions.
