How much would it cost to fit a new shower tray & screen
28 Oct 2014
Bedfordshire
I'm quite new to this site and before I get some quotes, do you know how much it would cost roughly to remove and fit a new shower tray and screens? The shower head and unit has been fixed to the wrong wall, so I'm thinking of relocating the shower head attachment to the exterior wall (to the left in the photo), but leaving the unit where it is to save costs.
This is the current manky shower and the shower tray is leaking around the plug hole:
I noticed that the shower tray is quite high, but I don't know why.
We're wondering if something like this could replace it:
http://www.plumbworld.co.uk/hydrolux-walk-in-shower-18622-28270
The reason it`s high is to get the waste pipe away - maybe it could be re routed and a neat tray like you linked to , fitted . Don`t know about £ though.
The walk in shower in the link is for a wet room, so no, it would not work in your situation as there is no door. 1200 x 800 cubicles can be bought from about £150.00 upwards depending on the quality.
As Nige says, a plinth is normally installed when it's not possible to route the waste pipe under the floor. It might be possible but the installer would need to have a look)
To remove and replace the shower base and screen I would put at about £300 (plus cost of base & screen).
It is likely that the bottom row of tiles will be damaged when removing the old base, so you would either need some more tiles or consider retiling the lot.
