I always wondered what is the normal amount of pressure loss with a sealed expansion vessel. All the manufacturers seem to state is that topping it up once or twice a year is normal.
I have 30x15ft of UFH, 15 double radiators, 4 towel rails.
I noticed when the whole system is first filled from a complete drain the pressure used to subsequently drop small amounts weekly over 3-6 months (i.e 0.2-0.4bar total). I presume this is all the air from the new water escaping?
It usually then settles down and will lose about 0.2-0.4bar over a year..
After fully draining 2 huge radiators, over the course of 3 months its dropped 0.15bar i.e 1.4 bar - 1.25, a tiny bit drops per month - again I presume this is the new water having the air escape, as there is no leak/weeping.
My question is, as plumbers how much pressure is usually lost per year on average (with no visible leaks anywhere obviously) on a system this size? and other than leaks, is some pressure always going to be lost from air being released/ oxidation etc?
