Just fitted a Labgear distribution amplifier. Where most equipment MIs just say to use the moulded on plug this has :
Alternatively the plug may be cut off and the power unit wired into a fused connection unit, fitted with an approved 3A fuse to BS1362. The PSUF is of class 2 construction and does not require a protective earth connection.
So far so good. But it goes further ;
If the power unit is not connected to the mains using the fused plug supplied or a fused connection unit, it must be protected by means of a fuse or MCB at the distribution board of rating no more than 6A.
Or reading between the lines - it's OK to connect it to the lighting circuit with a B6 MCB.
I can't recall having come across anything else where the MIs have allowed for anything other than a 3A BS1362 fuse in a plug of FCU. Pity they spoil it by using a blue LED that floodlights the bedroom - some black tape will be getting applied before tonight
