I’m intending to remove the laminate flooring in my bathroom and replace with floor tiles.
The problem I have is that it seems that at the time of putting down the laminate flooring, whoever fitted it has run continuous lengths of board straight under the skirting and through to the hall way. If you look at my album titled
‘tile job’
//www.diynot.com/network/600rob/albums/7897
You will see some pictures of the bathroom. The lamiate flooring, skirting boards and the doorway leading out to the hallway.
In particular the doorway opening has several boards that go straight across the door way and out into the hall. and the closeups of the skirting show the flooring going under the skirting.
I would like to keep the laminate flooring in the hallway and only tile the floor in the bathroom. but because it goes form one room to another in a continuous run im not sure how to remove it from the bathroom only. Here’s my questions
My problem/question is how I can successfully remove the flooring from the bathroom with out disturbing the floor in the hall way as it seems to go all the way under the skirts to the hallway.
Also there will be a join where the tiles meet the laminate at the door way so im not sure what options id have here…. I would have to cut both the tiles and the laminate at an angle to suit the door way.
The tiles would be 10mm thick so im assuming there will be a height difference where join is. Could I use one of those metal joining strips between the tiles and the laminate? Or any other product? suggestions
Would be good to hear from anyone who’s done something like this before and what they did/how they got around it.
‘tile job’
